I have two Vac Case tractors and are they negative ground or positive ground?
Nicholaus Sowde
01-29-2003 17:04:54
I have two Vac Case tractors and are they negative ground or positive ground? They are 1948 and 1949 models. Thanks alot for any information
Gene Dotson
01-29-2003 17:13:35
 Re: I have two Vac Case tractors and are they negative ground or positive ground? in reply to Nicholaus Sowder, 01-29-2003 17:04:54
Your VAC will have a positive ground system. All tractors built at the Rock Island plant were poitive ground, regardless of voltage and all tractors built at Racine are negative ground. Gene
Steve-IA
01-29-2003 18:25:07
 Re: Re: I have two Vac Case tractors and are they negative ground or positive ground? in reply to Gene Dotson, 01-29-2003 17:13:35
Gene,
Maybe this is a dumb question, but why were 2 different grounding systems built at the same time? Also, do you know where the Rock Island plant was located? I'm from the Davenport area.
Thanks,
Steve
Gene dotson
01-30-2003 02:42:36
 Re: Re: Re: I have two Vac Case tractors and are they negative ground or positive ground? in reply to Steve-IA, 01-29-2003 18:25:07
Sorry, but no, I don't know where the Rock Island plant was located. The ground systems were apparently because of the preferance of the engineering departments. Th early '30 series were built in Rock Island with positive ground and when production was moved to Racine, they became negative ground. Gene
Steve-IA
01-30-2003 18:18:03
 Re: Re: Re: Re: I have two Vac Case tractors and are they negative ground or positive ground? in reply to Gene dotson, 01-30-2003 02:42:36
Gene,
Thanks a lot for the info. There was a Case plant in Bettendorf until around 85 when they bought IH & moved over to the much nicer IH plant in Moline. This plant is closing in 3-4 years unfortunately. That will only leave JD in the Quad Cities. Cat, IH, & Case will have all left.
I'll do some research & see if I can find out where the old plant was.
Thanks again,
Steve
Tom Harrower
01-29-2003 22:26:42
third party image
Hi Nicholaus, here is a schematic out of a VA series service manual, sorry the picture is so big, it was hard to read the text at a smaller size. ...Tom
Nicholaus Sowder
02-01-2003 08:03:41
 Re: Re: Re: Re: I have two Vac Case tractors and are they negative ground or positive ground? in reply to Tom Harrower, 01-29-2003 22:26:42
I sure do appreciate all of your alls help. Thanks alot
