Cast nose on 70 series Case.
Pat
01-28-2003 17:18:39
Could someone tell me why On two 1070's that I have seen have cast iron nose pieces. The 970 I own has a fiberglass nose and in tan and orange. The tractors with the cast iron noses are tan and orange also. Just love those 70 series.
Casedude
01-29-2003 17:29:30
 Re: Cast nose on 70 series Case. in reply to Pat, 01-28-2003 17:18:39
What year are those tractors we have a 71 1070 fiberglass and a friend of ours has a white 1070 with fiberglass just tring to figure out when they changed.
Shane
01-30-2003 05:18:10
 Re: Re: Cast nose on 70 series Case. in reply to Casedude, 01-29-2003 17:29:30
I am not sure what year the one with the cast piece is. I know that the steering tilt is not on the floor but a small lever on the dash to the left of the key. I will go check serial numbers, as far as I know the whole tractor is original.
Casedude
01-30-2003 19:59:08
 Re: Re: Re: Cast nose on 70 series Case. in reply to Shane, 01-30-2003 05:18:10
Our 1070 has the tilt on the dash and then my friends has it on the floor. Gets me confused when i drive his tractor. Thanks for the info.
Jeb Mccranie
01-29-2003 15:59:51
My 1290 has a fiberglass nose. I kind of like them because they don't rust and are pretty tough. Less weight makes it handle better than a 770, I guess.
Shane
01-29-2003 06:44:31
I believe that the early ones had the iron noses, but I am not sure why. We have an early 1070 with the iron nose and 2 1070's without and 2 1270's without so your guess to why they were used and changed is as good as mine.
ed crankcase
01-28-2003 17:50:42
early 1070's had cast grills then later went to plastic. i had always heard it was for weight. i was thinking that early 970's had cast grills too. maybe 1170? 770-870's all had plastic grills
