Cylinder repacking
John G.
01-28-2003 08:11:27
Hi,
My local Case dealer here in CT closed down so now I don't have a source for questions or repairs. Anyway, I need to repack several cylinders on my 72 Case 580 CK Backhoe. I can get the parts online but not sure if i have the guts/know how to tackle the job without guidance. I have all the right tools and experience with repairs. Does anyone have a manual or instructions on taking these apart and repacking, etc. that they could copy. Perhaps you could e-mail or fax them to me? Any help is appreciated. Thanks much, John G.
Max
01-28-2003 17:58:10
 Re: Cylinder repacking in reply to John G., 01-28-2003 08:11:27
Piece of cake. I would suggest a 1 inch drive CP and 1-7/8 impact socket for the bolt and/or nut. As far as the gland nut, use a spanner wrench or make one. If the holes for the gland are worn out or the gland is extremely tight, make a 'Y' wrench from 1/4 inch thick plate to fit the gland, drill to 3/8" holes on the legs of the 'Y' wrench and weld the 'Y' wrench to the gland through the holes, then hit with a 4 lb dead blow hammer. Once disassembled, remove packing, back-up rings, wiper seals and gland bearing. Clean up gland and add new 1/4 inch hole for servicing next time. Also clean up gland bearing area in gland. When assembling remember wiper seal on inside faces its lip towards the oil and the outside faces its lip to the dirt. Lubricate and install on cylinder rod. Replace cheveron seals on piston with side facing towards the gland and the other facing the bolt/nut. Use medium strength threadlock on threads and tighten bolt/nut. Oil piston packing and install in cylinder, tighten gland and screw in lock screw(if holes on gland and cylinder tube don't line up, drill new starter hole). Hook backup on tractor and you're ready to dig. Good luck.
Illini Case
01-28-2003 09:04:29
Go for it! I do not have any instructions for you but I did my first two on my case 580 hoe becuase my dealer was charging too much. It was very easy.. The only hard part was removing the nut that holds the piston...(inside the cylinder). You may have to use a 3/4 inch drive socket with a cheater as it is torqued very high. If you do not have a spanner wrench a large pipe wrench will remove the packing gland. Replacing the rings and seals on the gland etc.. is easy, just remove and replace one at a time. Good Luck
GeoMo
01-28-2003 13:40:34
 Re: Re: Cylinder repacking in reply to Illini Case, 01-28-2003 09:04:29
Lay parts out in order or removal. Pay attention to O'ring and Backups.
