Oil in Trans and Final Drive
611B-Andy
01-27-2003 20:13:35
Just spent hours in the archives. Need to verify.
The Case-O-Matic and hydraulics use Dextron.
What about the final drive and Trans? Manual says 90w, in the archives, guys say Dextron??? Was there an oil change from when the manual was written?
Thanks Again.
K-Mo
01-28-2003 05:48:16
 Re: Oil in Trans and Final Drive in reply to 611B-Andy, 01-27-2003 20:13:35
Andy, I use the farm store Universal Hydraulic Fluid (Hytran) in my Case 630. If your 611 is the same as my 630, the Case-O-Matic fluid is also used for the external hydraulics. So if you connect different tractors to the same hydraulic implements, the fluids are going get mixed. I use the same fluid in everything.
K-Mo
John Saeli
01-28-2003 06:49:04
 Re: Re: Oil in Trans and Final Drive in reply to K-Mo, 01-28-2003 05:48:16
Andy is correct as to the fluid for the converter & hydraulic housing; Hy tran is an excellent choice. However, the 4 speed gearbox and final drive is a seperate housing and for that I would recomend 85W-140 gear oil. Good luck, John.
