Fair market value of case 830
Howard S.
01-27-2003 18:06:20
Hi fellas, I hope you don't mind holding my hand again. I have located a Case 830 diesel, currently owned by a retired farmer, that is for sale. It's a late comfort king, diesel, COM, and the owner says he has recently spent nearly $4000. to refurbish the tractor. Included in that is an engine overhaul, rewiring, water pump, and other odds and ends. I have not yet seen the tractor, but it's only about a 3 hour drive for me to do so. He was puzzled when I asked if he had much trouble with the COM, but he did say that it was expensive to change the oil in it. I sense that this tractor has been very well taken care of. My question is, what is the current fair market value of this tractor, assuming it turns out to be a solid 8 on a scale of ten. Thanks, Howard S.
David Berger
01-29-2003 13:31:50
 Re: fair market value of case 830 in reply to Howard S., 01-27-2003 18:06:20
It really depends on what it was like originally.I was wonderin if this 830 is a wide or narrow front? I've seen them listed at $2,000-
$5,000.For a restored one,and $4,000 put into it,
I would think its worth about $7,000.Good luck.
John Saeli
01-28-2003 07:23:19
Howard; S. Heiserman is real close. Still, it's hard to pin down. Last fall I saw a 930 CK bring $5200 and it was nothing special. In this weeks "Country Folks" a jobber has an 830CK with less than 2,000 hrs. that he claims looks showroom and he wants $10,000 for it. Good luck John.
Dale
01-29-2003 21:10:23
 Re: Re: Re: fair market value of case 830 in reply to CRAWLER HEAVEN, 01-28-2003 14:59:55
Hi; Give me a call /607-564-7536
John Saeli
01-28-2003 17:47:07
You didn't get the name "Fast Eddy" for nothing. You should stick with crawlers. I got $850. cash. John
SHeiserman
01-27-2003 19:10:47
The highest I've seen one go for was 3850. I don't know what he's asking but I'd think 3500-4500 would be ok.Of course I am biased. It has a common tranny and hydraulic system of 22 gals, that's why it is expensive to change C-O-M.
