David Brown Mufflers
jim
01-26-2003 11:30:37
Does anyone know how to straighten a ceramic David Brown muffler without damaging the ceramic coating ?
Jeb Mccranie
01-28-2003 15:44:40
 Re: David Brown Mufflers in reply to jim, 01-26-2003 11:30:37
If it is a dent in the side, Get a very small plunger(make sure it is clean) and pull the heck out of it. Works well on the oval mufflers.
James
01-26-2003 12:37:05
I'm going to guess that is impossible.
Most likely the ceramic is already broken off in the area which is bent.
My dealer told me the other day they are still available for some models. I did not have him verify that, but I thought I had heard they were no longer available.
Heat it up, straighten it, stay out of the trees!
jim
01-26-2003 15:12:20
 Re: Re: David Brown Mufflers in reply to James, 01-26-2003 12:37:05
Thanks James. It's on a newly purchased 880 and has only been slightly bent between the manifold and the bottom of the muffler. Not badly bent, just isn't perfect so I'll try the heat. Just thought there might be another way.
James
01-26-2003 17:58:17
 Re: Re: Re: David Brown Mufflers in reply to jim, 01-26-2003 15:12:20
Mine bent the bottom of the muffler itself which was easy to straighten (less the porcelain). If yours is bent 'below' the muffler on the round stack portion I would not try straightening that. It's quite difficult trying to straighten any type of tube which has been bent. If it's not bad you are probably better off leaving it alone.
