Case tractor
bill
01-26-2003 05:34:49
did Case make a row crop tractor called a 351 or 350?If so how manyand whats it worth.A friend says he knows where one is.Thanks
Jim M
01-26-2003 13:01:20
 Re: Case tractor in reply to bill, 01-26-2003 05:34:49
I'm working on restoring a 351 at this time. I think they made 948 351s in 1957 only. John has the specs right. They are very collectable and if you can get one with good tin get it. Mine came with 12.4 x 36 rubber on 11" rims and wide front. I have changed it to a tricycle front and 13.6 x 36 Firestone rear tires. I'm fixing her up to pull. Most people have never seen a 351. If you have any questions E-mail me and I will give you more details. Jim
John Saeli
01-26-2003 13:18:17
 Re: Re: Case tractor in reply to Jim M, 01-26-2003 13:01:20
Hey Guy's, I made a mistake on tire size; I converted mine from 13.9's to 13.6. The 13.6 actually stands a little taller than the 13.9. I goofed when I said 12.4. John
John H
01-26-2003 15:43:12
 Re: Re: Re: Case tractor in reply to John Saeli, 01-26-2003 13:18:17
Here goes for parts for the 300-350, Taken from Old Abe's News.
Bill Bickel Hood side panels 785-484-2288
Roger Hornbraker Grill parts 301-223-9005
Ted Johnson grill frames 612-867-2969
These folks may be able to help.
John Saeli
01-26-2003 10:30:16
Bill; CASE did make several versions of the "350", the "351" being the row crop version. I have a "351" adj. wide front. The "350" had a 164 cu. in. dry sleeve engine. Most had a triple range trans. (12 speed). Rubber size was 13.9 X 36. That size is getting hard to get but 12.4 X 36 looks real good on it and even stands a tad taller. It should have Eagle Hitch and remote hydraulics. Distributor ign. was standard; magneto was optional. They were only made for about 3 years so there insn't a flood of them, but I don't have the numbers. I'll bet CASEPOWER does when he answers. Good luck John
