Factory equipped high comp pistons?
SmartAxe
01-25-2003 07:11:55
In 1939 & the early 40's of CASE tractors, what was meant by being equipped with "high compression pistons" from the factory? Are they stepped head? Or button tops? Or flat tops extended up past the top of the block into the combustion chamber of the head a bit? Anyone know??
I've got a 1940 DC-4 the build card says was equipped with High comp pistons, not high altitude, but high compression. Is there a difference? The early D series has the lowest compression head on it (4570 same head on the C series) with the huge combustion chambers which would easily allow a taller or different designed piston top. Just wondering, as it's a running tractor and I don't want to pull the head off if I don't have to. Thanks,
-Mark
SmartAxe
01-26-2003 08:50:32
 Re: Re: Factory equipped high comp pistons? in reply to Don L., 01-25-2003 07:31:28
Thanks for the info, Don. Do you know how far above the deck of the block the high comp pistons extended and how much HP was gained over the standard pistons (ones level with the block's deck)? Oh, and are they 4" or 3 7/8" pistons? If it's a decent enough power gain and the price is right, I just may "need" a set for another project. Geez.. my mind's got the wheels turning again... Thanks
-Mark
