Case VAC how much should I pay?
Kelly C
01-24-2003 18:37:10
I am going to an auction Feb 1st they have 2 Vac's.
What would be a good price non restored but running?
I havent owned a Case as yet but they look kinda niffty.
Ted in Sacramento
01-28-2003 20:01:07
 Re: Case VAC how much should I pay? in reply to Kelly C, 01-24-2003 18:37:10
I bought my 48 VAO in Sacramento for $200 stuck, $51 for a carb on ebay, dist cap, wires, rotor, points, condensor, nuts, screws, gas line and fittings, etc at NAPA, $80, hydralic pump, carb linkage, original radiator cap $100, many parts still needed. Best $8 I spent was to Yesterday's Tractors. Plan to drive mine to the store for beer hope it has the HorsePower to get me home.
Dave in Mo
01-27-2003 09:35:42
We like our VAC because it starts/runs pretty well, but frankly, as the saying goes, it couldn't pull the hat off your head!
Steve
01-25-2003 11:19:47
Kelly
I'm from western PA. I was at an auction about a year ago, they had a 1954 VAC-14 in pretty solid mechanical cond, tinwork pretty rough, with the eagle hitch fuctioning well. It sold for $500. I personally wouldn't go too much higher than that, maybe $700-$800, because I've seen restored ones in great shape sell for $1400-$1500, and you never know what you're gonna get into in a restoration. Hope you find this info useful.
mj
01-24-2003 22:33:44
I've had 7 VAs and paid from 65 to 750 dollars for them. The 65 dollar one is minus wheels, tires, hood, cylinder head, carburetor and distributor. The $75 tractor was complete except for carb and distributor and had a stuck valve. The $750 VAC was a late one with live hydraulics and Eagle hitch. It was complete but dis-assembled; runs great now that it's put together again. At the 32nd Annual Machinery Consignment Auction here last year a VAC that had the earlier mid-mount lift and original but very faded paint brought $1500. These tractors are easy to work on, have good power and last a lifetime. One of my tractors, a 1947 VAC, is known to have never been re-clutched, rebuilt or retired(I use it almost every day, for one thing or another). I had 3 or 4 Ford 8 and 9ns and I wouldn't trade ONE of my VAs for the lot of them!
Ross Provine
01-24-2003 20:56:43
I bought a case VA (like a VAC but a standard front end instead of a row crop) for a little under 800 in August of last year. It had okay rear tires, a 12volt alternator and a homemade three pt and it ran great. It needed the hydraulic pump fixed, two front tires, a battery and it really needs paint. I'm in Illinois and sometimes I think I overpaid, I know I wouldn't pay more for the tractor in the condition I bought it. The VA series was about a 17-19 horse tractor on the belt and 13 on the drawbar. There's a profile on the case Va series on this page. The later VA series had live hydraulics (on the govenor I believe) for sure and maybe live pto and the eagle hitch which would make them worth more in my opinion
Hope this helped
Ross
mike
01-24-2003 18:51:45
The price depends on the overall condition of the tractor.I have purchased Vac's from 100.00 to 800.00 in the past.These tractors needed restoration,but were running well.
Les...fortunate
01-24-2003 18:50:35
You might get lucky and pick one up for just a few hundred. I paid $1400 for mine a couple years ago in the condition you are describing and most midwesterners (I'm in NH) think that was way too much.
Kelly C
01-24-2003 20:18:19
 Re: Re: Case VAC how much should I pay? in reply to Les...fortunate, 01-24-2003 18:50:35
What HP were these tractors?
TX Denny
01-24-2003 20:51:37
 Re: Re: Re: Case VAC how much should I pay? in reply to Kelly C, 01-24-2003 20:18:19
Nebraska put the 20.06 on the belt but didn't show hp for max drawbar in Wndell book. My calculation puts it at about 15.5 on the drawbar.
mj
01-24-2003 22:16:39
 Re: Re: Re: Re: Case VAC how much should I pay? in reply to TX Denny, 01-24-2003 20:51:37
In Official Nebraska Test number 431 a VAC equipped with standard gasoline engine (NOT the high altitude motor) developed 19.04 brake hp. and 15.00 drawbar hp. Maximum drawbar pull was measured at 2,768 lbs.(un-weighted).
Kelly C
01-24-2003 21:16:33
Thanks.
What could this tractor be used for?
I.E. Raking, plowing, mowing things like that.
Larry
01-25-2003 15:44:10
 Re: Re: Re: Re: Re: Case VAC how much should I pay? in reply to Kelly C, 01-24-2003 21:16:33
After one of his horses died my Grandpa farmed 120 acres with a 1947 VAC. If you can find the implemets for a VAC you can do a lot of work with them. They are one tough little tractor.
