VAC
Wayne
04-02-1999 03:33:27
As a young lad in the 50's my grandpappy let me drive his vac Case. I see that other models of the va series were made. What would the difference be?
Harold H
04-02-1999 17:50:11
 Re: VAC in reply to Wayne, 04-02-1999 03:33:27
Wayne,
VAC tricycle tractor, VA standard tractor, VAI industrial tractor, VAO orchard tractor, VAH high clearance tractor.
Harold H
Harold H
04-03-1999 20:14:35
 Re: Re: VAC in reply to Harold H, 04-02-1999 17:50:11
Dual tricycle was standard front end on the row crop VAC. A single front wheel or adjustable wide front axle were also optional on the VAC. The VAC was standard with 5.00-15 front and 9-32 rear tires. Cultivating clearance on the VAC was 20 1/8 inches. The VA standard was a wheel type or wheatland type depending on what it was referred to in different areas. The VA was standard with 6.00-16 front and 9-24 rear tires. The VA had a cultivating clearance of 16 7/8 inches. The VAI industrial tractor was standard with 6.00-16 multi rib front and 9-24 industrial tread rear tires. Cultivating clearance was not specified on the VAI. The VAO orchard tractor could be had with partial fenders or full coverage fenders. Standard tires on the VAO were 6.00-16 front and 9-24 rear. Cultivating clearance on the VAO was 16 7/8 inches. The VAH high clear tractor was standard with 6.00-16 front and 9-36 rear tires. Cultivating clearance was 30 inches on the VAH.
Harold H
Dug G.
04-02-1999 18:57:16
The va's-vac's were made in a wide array. They had the vac wide front fixed (standard), adjustable front axle and tricycle configuration. Some models had a lift sytstem of some type, and some of them didnt. There was a spring assist lift that was used, and the more popular eagle hitch (Case's version of the three point). They also made an industrial series, which usually is lower to the ground due to different tire sizes i believe. There was the vao which could have orchard sheetemtal around the tires and steering wheel, but not all orchards were like this. They can usually be id'd by under seat exhaust and "bodyguard" seat", and usually a standard axle. The vah is a high crop version of the vac's, with a adjustable front axle and eagle hitch. They also made a vas, a offset model vah, more or less, like a ih cub. They also made a vaiw, which was a little towmotor tractor produced around WWII, with either cast iron fenders, or sheetmetal fenders, and featured grab handles on the hood. Little long winded, but i think that covers it! Good Luck.
H. L.
04-02-1999 09:19:14
This site gives a pretty good look at the VA series Case tractors
Link
