Case 870
howard
01-23-2003 09:43:03
will someone dish the dirt on the 870? I have been looking for a 30 series case, but the 70 series is, of course, more available. I have heard of major problems with the powershift and hydraulics on these tractors, and at the prices they seem to command, you might as well buy a 3020. Any comments will be appreciated. Thanks, howard s.
Wolverine
01-24-2003 21:08:16
 Re: case 870 in reply to howard, 01-23-2003 09:43:03
My friend has 4 870 diesels all with powershift but one. They are great little tractors and give good power. But they can't touch my 1070 ! :)
howard s.
01-24-2003 06:38:59
Thanks to everyone for their comments in response to my posting of the other day. I have run the same case 630 tractor for some 43 years, so I'm not really concerned about the durability of the case lineup. All I'm really worried about is how well the 870-970 will hold it's money together as opposed to the johnny.I know it's not fair, but lots of folks can't seem to see past the green paint . I say this as a JD owner myself, having owned a 4430 with quad for 14 years. I love this machine, but I have spent a fair amount on keeping it up as well. It has aged to the point it needs a backup,and the 870-970 will definitely be on my must see list. thanks, howard s.
Ike
01-25-2003 16:26:51
 Re: Re: case 870 in reply to howard s., 01-24-2003 06:38:59
Howard, Glad to see these guys are pointing you in the right direction, they made a lot of good points,the Case engine awesome lug and fuel ecomomy,not to mention any wide front on a Deere what a joke! This is pretty strong Case country around me (west central Wisconsin) and the 870 and 3020 would bring pretty close to the same money if in the same shape. Good luck and don't be afraid of the power shift. Is your 4430 pretty thristy?!!
howard s.
01-25-2003 19:12:26
 Re: Re: Re: case 870 in reply to Ike, 01-25-2003 16:26:51
Ike, Yes, the 4430 likes diesel fuel. But what I like about this tractor is it's combination of power and convenience. It handles easily, and the quad range is a very nice transmission. It is also an open station tractor, which only increases it's work value, as far as I am concerned. The previous owner was a logger, and he put a front end under it that is absolutely bulletproof. This is not to say that the above qualities could not be obtained in another make and model. Thanks to everyone for their comments. howard s.
Brad Wies
01-23-2003 21:13:16
third party image
Hello Howard! I personally have no experience witht he 870 diesel, but I do use a 1070. DO NOT believe all these "horror stories" on the power shift! It is BS! I use my grandpa's 1070 that has almost 9,000 hours on it and it still has no problems! Even with it below 0 here in IL, when I hand pitch manure for him, I start the tractor 5-10 before I spread it. It is all in the operator, anything will last, just depends on how you are at keeping things up! I won't talk you out of a JD, they are fine tractor, but also get more money because of dealers. If you want a good tractor with decent power and long life the 870 is a good choice! I was already in love with the "70 series" when I was four, that pic was taken in 1990! -Brad
SHeiserman
01-23-2003 20:04:57
A tractor is only as good as the man running it. Perhaps this is why Deere folks have such a hard time with Case. We've run 1370 and 1070, no problems with Powershift or anything else. They are good tractors and you'll be glad you bought it. If you're in cold climate need to let powershift warm up before using it.
Shane
01-23-2003 19:42:55
We run several 1070's and several 1270's and have only had one powershift go out. This was due to lack of engineering and has since been updated. The 870's are good little tractors. All of our Case's have over 4000 hrs but one and have caused very little trouble.
Vinnie
01-23-2003 17:56:59
The case has the best front end for loader work of the two. If you want a cab on one the case has a far better cab and ac set up. The powershift has held up good on most in this area and the engines run supper cheap. All tractors have failures no matter what brand. As far as this area goes the JD sells much higher than the case. The reason for that in this area there are a lot of JD dealers here that bad mouth all other makes so they sell better.
Thad
01-23-2003 15:41:38
The 870 case is very good tractor. As far as the powershift if used right and hyd filters serviced. It gives very little trouble the hyd are almost the same as the 30 series with the exception of the brakes are diffrent. As far as comparing a 870 to a 3020 its not fair the 870 will whip the 3020 for power and fuel economy. I sell both tractors and both make good tractors but if i was buying i would go for the case. Good luck Thad.
Richard
01-24-2003 11:12:27
 Re: Re: case 870 in reply to Thad , 01-23-2003 15:41:38
Well I've driven an 870 here since it was brand new, I later bought it and she now has over 10,000 hours on the clock and shes ready for another days work whenever I turn the key. We've had a tremendous run out of this machine. Snow, drought you name it, she's farmed us through the lot!
