Hi dbb62, It took poking through 4 different manuals, bu here's the weight information that you requested. I know that you didn't want the weights for ALL of these models... but I figured I might as well type it all in once and get it out of the way for all those future times that this same question is going to get asked: SHIPPING WEIGHT - S SERIES TRACTORS Model "S" on 12-26 tires: 3,811 lbs. Model "SC" (dual front wheels) on 11-38 tires: 4,513 lbs. Model "SC" (single front wheel) on 11-38 tires: 4,695 lbs. Model "SC" (adjustable front axle) on 11-38 tires: 4,452 lbs. Model "SO" on 12-26 tires: 3,814 lbs. Model "SI" on 13.00-24 tires: 3,893 lbs. Model "SI" on 12.00-24 dual rear tires: 6,400 lbs. SHIPPING WEIGHT - D SERIES TRACTORS Model "D" on 12-26 tires: 4,433 lbs. Model "DO" (Orchard) on 13-26 tires: 4,602 lbs. Model "DC3" (Gen. Purpose) on 11-38 tires: 4,766 lbs. Model "DC4" on 11-38 tires: 4,471 lbs. Model "DC3" (Gen. Purpose with adjustable front axle) on 11-38 tires: 4,622 lbs. Model "DCS" on 11-38 tires: 6,360 lbs. Model "DI" with 13.00-24 real single tires, 6.00-16 front tires: 5,150 lbs. Of course, none of the weights I've listed probably include cast iron wheel weights or fluid-loaded tires. I've heard that a DC can push 7,000 lbs. fully loaded... although I can't verify that information. Hope this helps, -Schotte
