Case-o-matic tranny
howard
01-21-2003 08:14:56
Can someone give me the lowdown on the c-o-m? I have a chance to purchase a 630 d with c-o-m at a down the line price, but it has been a very long time since I have run a c-o-m. parts, operation and so on and so forth. thanks howard s
howard
01-22-2003 05:22:15
 Re: case-o-matic tranny in reply to howard, 01-21-2003 08:14:56
Thanks, John Saeli, for jogging my memory as to what a pain in the wazoo the COM can be. This is an Iowa tractor, which is a good sign, but I think I'll let it slide on by. I, too, have a 630 with TRD, so I don't need one, anyway. Thanks, Howard S.
Casedude
01-22-2003 15:20:54
 Re: Re: case-o-matic tranny in reply to howard, 01-22-2003 05:22:15
Where at in iowa is it. I am in the Southeastern part. Thanks.
howard
01-22-2003 18:10:44
 Re: Re: Re: case-o-matic tranny in reply to Casedude, 01-22-2003 15:20:54
The tractor is at haley implement co.in carroll Howard
John Saeli
01-21-2003 14:16:51
Howard; How much do you remember? I had a 630 with COM now I have a 630 with triple range. The COM is a torque converter driving a mechanical 8 speed trans. The converter had a feature that allowed the operator to lock it into direct drive after you were in motion. Damage can result from heat if it were abused by too much slippage; usually by leaving it in too high a gear for whatever load it was under. Have you driven it? At idle, will it go in any gear you choose or does it grind? A slight grind is to be expected, but abuse warps the discs and allows too much drag on the converter. Does the direct drive work? Another thing I would check for is compression leaking into the radiator. In cold climates, guys use either and the 188 does not like it. Good luck John
