F-30 heats up and decal
Okla/Kans Bill
01-20-2003 18:46:14
I posted this in the IH room and got nada and so im hopin sombody in here might have an answer--I was discing with a 37 F-30 and an IH 16ft wing disc without the wings. She sounded great all the time, but she got hot. Finally it lost power on a turn, I couldnt save her and she died. Then she boiled over 2 gal of antifreez. I didnt have a rubber gasket on the radiator cap (i do now) so that might explain that, but how come she got hot in the first place. I was only out about 3 hrs and it was so cold I had a flap cap jacket and gloves on. I was discing cross furrows at an angle and I think the ony way I kept warm was being jostled around in my clothes, but my hands froze. Also, I noticed a egg shaped decal, or 1/2 of it under the air cleaner bracket on the radiator. It had a thin white line around it and it was blue. What was it? Thanks
Binder-Man
01-21-2003 15:19:33
 Re: F-30 heats up and decal in reply to Okla/Kans Bill, 01-20-2003 18:46:14
Randy is right about your anti-freeze, getting it this hot, after it cooled off did it start alright? A 16 foot disc to me is little to big for a F-30..Binder-Man
Binder-Man
01-21-2003 15:19:18
Larry
01-21-2003 09:42:51
Could be you were working it too hard. A 16 foot disc sounds kind of big for a f-30 to me.
Randy
01-20-2003 19:35:02
If you are using 100% antifreeze, that well could be your problem. Too much antifreeze is not a good thing. Try a 50-50 if your weather permits.
CASEPOWER
01-20-2003 19:28:35
Your gasket won't help. the radiator is not a pressure type. Chances are if it heated it was because of lack of flow. A thermosyphon system must be very clean and free of obstructions because there is no water pump to force the water through. It works on a "Heat rises" system a very good flush may help if you have not hurt it when you overheated it. I found the best thing to do is buy a new radiator core.
