What oil is needed to refill the oil bath air filter
Robert P
01-20-2003 17:40:02
Just found that the cup retaining the oil for the air filter is almost empty. What oil weight should I use ? How often do I need to check or replace the oil ? Questions apply for my 1952 CASE VAC.
Thanks.
Les...fortunate
01-21-2003 03:59:38
 Re: What oil is needed to refill the oil bath air filter in reply to Robert P, 01-20-2003 17:40:02
I have a '52 VAC. The owner's manual says to use 20 weight oil. Get yourself an owner's manual. I was lucky. When I bought the tractor, the original one came with it.
Robert P
01-21-2003 10:11:13
 Re: Re: What oil is needed to refill the oil bath air filter in reply to Les...fortunate, 01-21-2003 03:59:38
When I got my VAC I ordered the shop manual. I guess I'll have to acquire the owner's manual which is more "frienly user" and informative for my needs.
I'm only getting to know the tractor, thanks for your advice.
Robert
glenn
01-21-2003 03:45:14
use the same as crank case. keep it clean and keep it filled. running it low or no oil is the same as using a newer motor with out a filter.
keeping the dirt out is important. it's cheaper to keep clean oil in the bath, than overhauling motor. glenn
CJW in IL
01-24-2003 12:47:56
 Re: Re: What oil is needed to refill the oil bath air filter in reply to glenn, 01-21-2003 03:45:14
WHAT IS THE BEST WAY TO CLEAN OUT AN OLD GUUMY OIL BATH?
Jim P
01-20-2003 21:33:34
I have always used the same oil I used in the engine. but someone told me you should use a non-detergent oil because the dirt will settle out to the bottom like it should but if you use a high detergent oil the dirt will stay in suppension and clog up your screens. I would say use 30 wt. summer and 20 wt winter.
Joe (Wa)
01-20-2003 19:17:40
Hi Robert, if the oil level is down it probably hasn't had much attention lately. Use the same oil as in the engine crankcase which was originally 30 wt. Take a look @ the wire mesh above the oil cup. 52' should have a removeable precleaner protruding from the canister about 1-�". If it is caked up pry it out and check the wire mesh in the main filter body. If that mesh is also plugged it will take considerable soaking or the extreme is unsoldering the retainer, pulling the mesh and cleaning it. Good luck, Joe
twopop
01-20-2003 18:40:20
you should use 30 wt.motor oil
John Saeli
01-20-2003 18:04:23
Robert; I just use engine oil, 15W40. The directions said to service daily, but doing with these old tractors what we do I service mine seasonally when I change the oil and service the tractor. Good luck John
