Diode
pat moore
01-19-2003 12:06:48
just put a gm alt on my d/b 885 what duz a 50 amp diode look like
Eddie in KY
01-20-2003 17:26:53
 Re: diode in reply to pat moore, 01-19-2003 12:06:48
Lets back up and let me ask this. What do you need a diode for? What do you want it to do?
TB
01-19-2003 19:21:37
Depending on the switch used sometimes you have to use a diode in the exciter wire, Rat Shack 1A, 50V, $0.49. There are some large diodes inside the alternator but I usually take them to a shop for that kind of work or just get a rebuilt alternator.
Eddie in KY
01-19-2003 17:02:40
Ive put delco alternators on many diiferent machines, but I have no idea what you need a diode for. If you are using a one wire alternator thats all you need, the one wire running to the battery. If your using a standard auto style alt., one wire is hooked up constant hot, the other is swiched hot. Please let me know what you are using.
TX Denny
01-20-2003 07:39:55
 Re: Re: diode in reply to Eddie in KY, 01-19-2003 17:02:40
Not sure of your question. If you think one of the main diodes inside the alternator is bad, they are about the diameter of a nickel and pressed into the alternator frame. If you are using an alterantor that has two wires, one of which is for exciting the field, Radio shack sells diodes that will work. I usually pick one with a 50+ voltage rating and 5 amps or more. Without this diode in the exciter circuit, voltage will be fed back to the ignition and you won't be able to turn off the tractor.
