Missing # plate
kztractor
01-19-2003 10:49:03
I have what I beleive to be a VAC that I beleive
to be from the forties. When I bought it the serial # plate was gone. it was from an estate and
nobody there was sure where it had come from. My question is, can you determine the year by casting #s or the # stamped on the top right rear
of the engine block?
John H
01-19-2003 13:38:28
 Re: missing # plate in reply to kztractor, 01-19-2003 10:49:03
Not if its a "V" series they didn't have the serial number stamped on the block. If someone has a parts book they might be able to narrow it down. Does it have the eagle hitch? Does the steering stick out the side around the front? Or better yet can you post a picture? There are many knowlegable "V" guys on the board.
kztractor
01-21-2003 16:36:07
 Re: Re: missing # plate in reply to John H, 01-19-2003 13:38:28
Thanks John H for the reply. the tractor has center mounted hydralics with a piston pump under the flywheel,no eagle hitch,and the steering sticks out the side and goes to a wide front end with pressed steel wheels rather than cast centers,it also has a square seat with a loop on the back presumably to guide the rod that goes down to the P.T.O on/off lever right on top of the P.T.O. housing.
