Elmer, I need ammo
James
01-18-2003 18:20:16
I took the right final drive unit off my 996 to my dealer to have new seals installed. They also replaced some bearings they said were bad.
My problem arose when I brought the final drive home and reinstalled it. Everything went fairly smoothly until I tried to move the tractor. The right wheel was locked up. I noticed if I held the diff. lock or the left brake the right wheel would turn. I moved about 10 feet backwards and 10 feet forwards.
I tore it back apart thinking I had put the brake shoes on the wrong side (even though they didn't bind against the drum as I was installing it). However, I soon realized they did not press the brake drum far enough on the drive shaft and the inside of the drum was rubbing against the rear axle oil seal housing. The lip was tore off the oil seal housing all the way around. (It's going to be a bear to get out this time)
My question for you is: How can I prove to the dealer that this is their fault? The only thing I see in the service manual is in the 990 section "Replacing the Spur Pinion Shafts". It says drive the brake drum ""fully home"". Should "fully home" have been obvious for them? Is there a measurement or anything else they should have checked?
I can see by looking at the drum and the oil seal housing that they were rubbing together. I would just like to hear from an 'expert' that the dealership should have done a better job of seating the drum, and it is their responsibility to fix the problem. I haven't talked to them yet.
Thanks
James
01-20-2003 17:02:55
 Re: Elmer, I need ammo in reply to James, 01-18-2003 18:20:16
To my surprise, the dealership said they would come get my tractor and fix it.
