WET CLUTCH OIL
CASE 900 MAN
01-18-2003 14:01:46
I have a Case 900,1957 with the hand clutch,my question is,does the oil for the clutch come from the engin, or, trans.,or do you have to put oil in the clutch housing,I have been getting different answers on this and would like to know what is the correct answer,Thank you
Roger
01-18-2003 20:13:43
 Re: WET CLUTCH OIL in reply to CASE 900 MAN, 01-18-2003 14:01:46
John is exactly right, there is a drilled passage in the crankshaft that feeds oil from the rear main bearing to the clutch to oil it. Look inside the housing sometime, it will be the cleanest clutch you will ever see. I've got a '63 930 LP with the hand clutch & I've never felt a smoother engaging clutch anywhere, I wish my Farmall M was that smooth..... ...Roger
caseman-d
01-18-2003 15:46:50
congradulation, only 750 diesels made and 150 LPs. Total of 900 made. I have a 57 diesel also.
caseman-d
CASE 900 MAN
01-18-2003 16:18:00
 Re: Re: WET CLUTCH OIL in reply to caseman-d, 01-18-2003 15:46:50
I plan to pull with this tractor in the stock class
Jim M
01-18-2003 20:07:56
 Re: Re: Re: WET CLUTCH OIL in reply to CASE 900 MAN, 01-18-2003 16:18:00
Send me your E-mail address and I will send you a picture of my dads 900 gas tractor pulling on New Years Day. Pulled yesterday and won stock class and I pulled it and won Antique class
John Saeli
01-18-2003 14:12:11
900 man; This is the straight facts that you can go to the bank with. Engine oil is constantly flushing thru the clutch housing, changing itself. When you drain the crankcase, drain the clutch housing. When you fill the crankcase after a change, add about an extra quart. Good luck
