Plows
Bob
01-17-2003 18:11:12
Does anybody have information on different models of Case plows built in the early to mid 60's? The particular plow I am looking for had EXE stamped on the back of the mold boards. Any help would be appreciated.
John Saeli
01-17-2003 19:08:22
 Re: Plows in reply to Bob, 01-17-2003 18:11:12
Bob CASE built a lot of different plows in the 60's. Trailer, mounted and semi-mounted for the Eagle Hitch, and mounted and semi- mounted for the later Draft O Matics. They built many different bottoms for different soils, I believe the EXE was more of a speciality bottom as opposed to the EXB and EXC being general purpose.
If you could be more specific I might be able to help more. Somewhere in the archives I have a listing of the moldboards
Bob
01-18-2003 11:18:13
 Re: Re: Plows in reply to John Saeli, 01-17-2003 19:08:22
John, the only plows i have seen with the exe bottoms where 3 point hitch 2 bottom and a semi mount 5 bottom, they were the best plows i ever seen when plowing sod, i don't know what model they were supposed to be, i have had the exc they will not turn sod ground over like it should be. i would apperciate any help. Thanks Bob
John Saeli
01-18-2003 13:38:57
 Re: Re: Re: Plows in reply to Bob, 01-18-2003 11:18:13
Bob; What size plows are you looking for? Last Spring I saw quite a few at auctions,,mostly 4 bottom Semi Mount. Seems as though guys buy them for the coulters, and other parts, then sell the rest off.
Bob
01-19-2003 08:45:56
 Re: Re: Re: Re: Plows in reply to John Saeli, 01-18-2003 13:38:57
John, it really dosen't matter 3or 4 bottom 3 point hitch or semi mounts would work fine, but would like to have the exe bottoms on them Thanks again
