SC tractor questions?
Mike Schwartz
01-12-2003 20:14:50
Hello, I just brought home my first case tractor. I think that it is a 1942 SC, serial number was 4606181SC, does this mean that it was the 6181 SC produced in '42? It has a wide front axle and a mower mounted on the rear. There is a handle located under the seat on the right side that is connected to the PTO housing area, is this somehow hooked to a power lift mechanism? Where is the best place to find a operators manual? Has dual fuel manifold and starting tank. Are cracked water jackets common to this model, this one is but I don't know how bad, loaded it on truck dry, runs well. Thanks for all of your help, I'm sure that there will be more questions to follow, thanks, Mike Schwartz.
Here's an Operator's manual for you...
01-13-2003 10:54:02
 Re: SC tractor questions? in reply to Mike Schwartz, 01-12-2003 20:14:50
One came up for sale on Ebay today.
Hope this helps, -Schotte
Mike Schotte
01-12-2003 21:17:39
Hi Mike (MAN- we are getting WAY too many Mike S.'s around here!)
Congratulations on getting the SC. I'm a big fan of that model.
I'll try to help you with some of your questions in the order that you asked them:
1) You are correct, it is a 1942 model tractor, but from what I have read previously- the serial numbers were used for the ENTIRE production run... not for each individual model type. This means that tractor number 6180 might have been an "S" or a "DC" model, while your number 6181 just happened to be an "SC".
2) Your '42 model would probably have been equipped with the "motor lift"-from the factory- and it would have been actuated by a foot pedal on the right side of the PTO housing. If someone has changed out the rear PTO assembly- then it's possible that you could have the hydraulic lifting bail (which would have a hydraulic control lever like you describe.) Maybe with a little more info we can narrow down what you've got to work with.
3) You can find Operator's Manuals up for sale from time to time on Ebay. I believe that Jen sales offers reprints of the parts and service manuals- so they might offer the operator's manual as well. (I'm not sure)
4) YES- cracked water jackets are very common on all the SCs that I've seen. They usually are cracked right behind the carburetor. So far, I've only seen one tractor that WASN'T cracked there. My SC has been running with a patched water jacket for over 20 years and it still runs fine and leak-free.
I'll be happy to help you with any other questions if I can.
Regards, -Schotte
John Saeli
01-13-2003 04:50:45
 Re: Re: SC tractor questions? in reply to Mike Schotte, 01-12-2003 21:17:39
Mike & Mike; Just couldn't let this pass without my 2 cents worth; From my experience, the only thing that will crack any CASE engine block is freezing. Anti-freeze is real cheap. I have 6 SCs around here, none have a cracked block. Overnite temps here are forcast to be in the single digits F.. I believe operators manuals are still available from CASE. The number is 5289. A lot of items are still available, trouble is with the lazy parts men behind the counter, especially if they are old IH men. Good- luck.
Mike Schotte
01-13-2003 05:33:25
 Re: Re: Re: SC tractor questions? in reply to John Saeli, 01-13-2003 04:50:45
You are correct about the benefits of anti-freeze, John.
Just so you know- I take care of my tractors... but the ones I have were cracked sometime in the 50 years BEFORE I owned them.
There aren't too many SCs in my part of the country- but of the 5 SCs I've seen, 3 of them were cracked at the exact same location on the water jacket. This is odd, since Texas is not known for it's freezing weather!
I own two SCs with patched blocks, and one '45 with a stuck engine (but a nice uncracked block).
I often wonder when I finally take my '49SC out of service and do a "full" restore on it if I will be brave enough to remove that bolt on patch and see what horror lies beneath.
Regards, -Schotte
