Cold weather start
Robert P
01-12-2003 17:45:58
My VAC was running great till New Year. The little machine is always outside. Recently I can't get it to start. The weather is colder, well below freezing and I'd like to know if there is a procedure for cold weather start-up ? Should I pump the gaz pedal a few times and use full choke ? Thanks for your advice.
Gordon
01-14-2003 06:54:04
 Re: Cold weather start in reply to Robert P, 01-12-2003 17:45:58
Years ago I went from a D16 to D15Y to D23 then there was nothing left.
TX Denny
01-13-2003 07:19:16
In cold weather, full choke is usually required for all tractors - some require it even in warm weather. I usually do full choke until it fires and then push in the choke until it runs smoothly. Usually the choke is unnecessary after 30 seconds to 2 minutes.
Gordon
01-12-2003 20:01:40
You can pump the pedal all you want all it will do is keep the foot warm and ankle loose. Now check points and condensor plugs and wires.You have to get to know the tractor.Get Autolite plugs I do not like chams they do not work.
Robert Paris
01-13-2003 02:28:55
 Re: Re: Cold weather start in reply to Gordon, 01-12-2003 20:01:40
Thanks for the hint. I'll do what you suggest. My plugs are Champion D-16 I'll switch brand and see what happens.
GeoMo
01-13-2003 05:02:11
 Re: Re: Re: Cold weather start in reply to Robert Paris, 01-13-2003 02:28:55
I have trouble with water collecting in the breather. My VAC sits outside but, will always start if it has gas and points etc. ok
