SC Mag Question
JonCT
01-11-2003 16:59:34
I recently bought two Case SC's in fair shape and am attempting to get them runnig.
The Model 41 mag (Only got one mag with both tractors)did not spark at first then I reworked it and now I get spark but from TWO of the plug wires at the SAME time when bench tested. I tried the mag to start the tractor and no go. Timing and all appear correct.
Question..... . Is there a problem with the mag...
Bad cap? or is this normal..... two cylinders spark at the same time??
Thanks!
EARL S.
01-12-2003 18:31:50
 Re: SC Mag Question in reply to JonCT, 01-11-2003 16:59:34
John, A common problem on mag's that have brushes is what we call carbon track on the rotor. The other thing would be to check and make sure the brushes are not too short. Brushes and springs are OK and not hanging up in the cap or cracked cap.E -mail if you need help. Earl Seamands
Mike Schotte
01-11-2003 17:37:39
Hi JonCT,
Let me know what you find out- I don't have a Model 41 mag, but I've got one of the 4JMA mags with what may be a similar issue.
When bench testing the mag- I will get spark on the #1 wire for THREE out of the FOUR snaps of the impulse coupling.
I haven't connected multiple wires- but it stands to reason that I might have spark on multiple cylinders at the same time.
I don't know if this is a problem or not. It probably doesn't affect functionality- but I don't know how I'm supposed to time the magneto to the tractor when I can't isolate a single cylinder!
Keep us posted, -Schotte
