Help with power steering pump for 430
Jim Y
01-11-2003 16:54:07
I am need of some help finding a pressure relief spring and ball for my case 430. Or may be a good replacement pump. Or if some knows sombody who rebuilds power steering pumps. My pump was manufactured by someone else for case. It has a small metal plate that has the numbers 4535 on it. It is the type pump which is driven by the cam gear. Or from the same area a vac hydraulic pump is from.
Thanks in advance if any one could help me with this problem. Jim Y.
Joe (Wa)
01-12-2003 09:30:47
 Re: Help with power steering pump for 430 in reply to Jim Y, 01-11-2003 16:54:07
Hi Jim, you probably have the Barnes gear drive pump Case p/n G45157 with 1 qt reservoir ???
The pump is listed as "non-serviceable" in the service manual but is fairly easy to get apart & back together. You may be able to substitute a ball bearing and spring for the relief valve. Relief press is 1050 psi adjusted with washer(s) under the spring in the retaining plug. Joe
case poor in pa
01-11-2003 18:37:00
try [email protected] hes got lots of stuff
