No clutch pressure 530ck
rey
01-11-2003 09:35:56
can anybody help me find out what could be the cause of this. i disconnect the line going to the clutch pressure gauge and nothing comes out shouldn't fluid come out at 125 psi. what could be the cause could it be the pump or the torque converter? any help would be great.
John Saeli
01-11-2003 16:55:59
 Re: no clutch pressure 530ck in reply to rey, 01-11-2003 09:35:56
rey; Could be something simple like a stuck spool, or if your luck is like mine, something happened to the pump.
rey
01-12-2003 05:35:35
 Re: Re: no clutch pressure 530ck in reply to John Saeli, 01-11-2003 16:55:59
is the pump a big job? they make it look simple in the book but they do not tell me what has to be removed i had frozen sludge now the pump seems to have lost its prime i disconnected the hose going to the filter and nothing comes out.
also the filter in the book shows the hose coming from the trans going to the bottom port on the filter but on mine the bottom port goes to the trans cooler. could someone maybe have hooked it up wrong
John Saeli
01-12-2003 15:16:33
 Re: Re: Re: no clutch pressure 530ck in reply to rey, 01-12-2003 05:35:35
REY; It is no easy job to change the pump. When you mentioned the ice, is it possible you still have ice in the sump, or the pump tube stopping the flow of oil. If you haven't already, I would get the tractor inside and make sure everything is thawed out. Good luck.
rey
01-11-2003 10:07:22
i changed the fluid to case hy tran ultra and i replaced the filter i also removed the regulator and it seemed fine the spring was pretty hard to push
