DC WIDE FRONT-what kinda wheels fit
Tom Bush
01-10-2003 18:19:58
Hi Guys, need a little help,I just bought a wide front and they tell me the "case" wheel is all "it's own" Isn't there anything else that will work?It's a 5 hole pattern,looks to be about a 3" center and maybe 2 3/4" center to center(I maybe off a little)on the wheel bolts.But surely there's something that will interchange. Thanks,Tom
DKase
01-12-2003 17:43:11
 Re: DC WIDE FRONT-what kinda wheels fit in reply to Tom Bush , 01-10-2003 18:19:58
Buick, and Olds wheels fit out of the early 60's. Make sure you measure the offset, and the center hole. Good luck
Tom Bush
01-12-2003 18:34:15
 Re: Re: DC WIDE FRONT-what kinda wheels fit in reply to DKase, 01-12-2003 17:43:11
Thanks,DKase I appreciate the reply. Tom
John Saeli
01-11-2003 17:10:54
Tom; If you have the 5 hole hub, yours takes the "stamped" steel rim, readily available, not that uncommon. The optional rim was the heavy cast rim that only CASE used, but that was 3 hole.
Tom Bush
01-11-2003 18:37:49
 Re: Re: DC WIDE FRONT-what kinda wheels fit in reply to John Saeli, 01-11-2003 17:10:54
Thanks John,I appreciate the reply.Yeah my tricycle frt has the "cast" but this guy told me it would really be hard to find the steel wheels,so far I haven't found any.I really didn't want to get new ones,but I guess I'll do whatever I gotta do. Thanks ,Tom
John Saeli
01-12-2003 15:09:45
 Re: Re: Re: DC WIDE FRONT-what kinda wheels fit in reply to Tom Bush, 01-11-2003 18:37:49
Tom; New stamped rims should be no more than $40.00 a piece and easily available. If you have problems e mail me.
Tom Bush
01-12-2003 16:52:06
 Re: Re: Re: Re: DC WIDE FRONT-what kinda wheels fit in reply to John Saeli, 01-12-2003 15:09:45
Thank You again,I really appreciate that. Tom
