Question
Vick Cardoza
01-10-2003 11:55:59
Have a Case tractor that I'm trying to find out what year it is. I can't find any numbers stamped on the tractor for serial numbers. Single wheel, magnito, 4 spark plugs, large clutch wheel on side and side rod that comes around tractor that steers it. As you can tell I don't know a hek of alot about them. Please info. on it or where I can get some. Thank you.
John H
01-10-2003 13:35:01
 Re: Question in reply to Vick Cardoza, 01-10-2003 11:55:59
If you have the "chicken roost" steering arm and a hand clutch it should be a Flameau series. There should be a serial/model plate on the dash, IE-choke, lights, etc.. If this has be lost look on the left side of the block where it attaches to the transmission housing and there will be a number stamped there plus the model, SC, DC, LA. If its the V series it won't have the number there. Its a 7 digit number. Subtract 4 from the first two numbers and this gives you the year of manufacture. Let us know what you find and post any other questions. The folks here are very helpful.
Vicke Cardoza
01-14-2003 07:18:13
 Re: Re: Question in reply to John H, 01-10-2003 13:35:01
Went out and looked and found the plate. Could not find the number on the block. 505323 DC. Can you tell me from that what year it is?
Vicke Cardoza
01-13-2003 08:45:21
Haven't gone out and looked at the tractor yet. One more question. In all the pictures that I have looked at the front ends have dual tires. This one has a yoke and only one tire. Is that unusal or that there just isn't pictures of it.
It also has oil bath on left side. Has a short medal shift that is high-low gear. I think it is a 4 or 5 speed. Does have hand clutch and chicken roost. Will check it out more this evening. Looking for a maginato for it. It does work. It is gravity flow no fuel pump. Thanks.
