G148 oil slinger...
Keith Alexander
01-07-2003 20:49:09
Reassembling the g148 engine in my 59 311b and the IT manual kind of shows an oil slinger?? now it has been a year since I tore into this but I was pretty careful, tie wrapped like parts, zip lock bags with notes attached and I cannot find anything that looks like a slinger.
order I have is block, thrust pieces,gear, cover,pulley. any suggestions.
In addition were does the second thrust washer go (if it is used)
Thanks for the help
Keith Dexter NY
Joe (Wa)
01-07-2003 22:52:46
 Re: g148 oil slinger... in reply to Keith Alexander, 01-07-2003 20:49:09
HI Keith, I also have a '59 311b g148 which needs an out of frame ovhl. I have Case service & parts manuals. Both show a slinger between the gear and front oil seal. Assembly order in the parts book starting @ the front bearing: (woodruff key in shaft):
1. washer, crankshaft thrust - vt3376
2. shim(s), crankshaft - vt3368 (010")
3. shim(s), crankshaft - vt3367 (.002") 4. spacer, crankshaft - vt3377
5. washer, crankshaft thrust - vt3376
6. pin, crankshaft thrust washer - vt3364(2) [pins appear to aling shims between the two thrust washers]
7. plate, crankshaft thrust - vt3230
8. gear, crankshaft (24T) - vt3225
9. slinger oil, crankshaft front bearing - vt3220
10. oil seal, crankshaft front - vt3373
11. dust seal, drive pulley - vt3380
12. pulley, fan belt drive - vt136 (g1162)
13. collar, starting jaw - vt3366
14. nut, starting crank jaw vt136 - vt4534
