No Heat in Cab.
Jud Simons
01-07-2003 13:03:20
Can anyone explain to me what might be wrong with my heat. I own a CI 4210 1996. I have replaced the thermostate and the lines are clear but yet there is still no heat in my cab. Any ideas welcome, thanks.
Bernard le m�cano
01-08-2003 19:40:48
 Re: No Heat in Cab. in reply to Jud Simons, 01-07-2003 13:03:20
Hi Jud,nice idea for the girl in bikkini, but if the cab is cold,maybe she's not want to go with you. Check if the valve, that adjust temperature,are open.Then fill your radiator to the cap and lift the front of the tractor as you can and run the engine to 2000 R.P.M to allow the air to go out.Maybe when you have drain the coolant, the heater valve was open and the core were empty.There was air in the system. Bernard le m�cano QC CANADA
CASEPOWER
01-07-2003 18:40:18
Just a guess, but if the heater core is higher then the engine and radiator you will have to prime it with some antifreeze to get it to pump water through.
CASEPOWER
01-07-2003 18:39:53
CASEPOWER
01-07-2003 18:39:41
Tremayne
01-07-2003 15:52:44
Does the motor get to operating temp? If no then the problem is in the cooling system. If the motor does get to operating temp, is there a shutoff valve in one or both of the heater hoses? Is there any flow through the lines? Does the fan work? Is the heater core plugged up? Did it ever work? Call your local dealer, they might have run across the problem before. A cab heater is basically a small radiator in the cab. Not familiar with that new of a tractor, but for what it is worth this is how I would go about it. I hope this helps you. Good luck!
Tremayne
01-07-2003 15:52:02
Tremayne
01-07-2003 15:49:43
Tremayne
01-07-2003 15:48:34
Tremayne
01-07-2003 15:48:16
Tremayne
01-07-2003 15:47:58
Tremayne
01-07-2003 15:47:49
case poor in pa
01-07-2003 19:23:13
 Re: Re: No Heat in Cab. in reply to Tremayne, 01-07-2003 15:47:49
in regards to your answers we heard ya the first time... personally id get a blonde in a bikkinni and put her in there that would heat me up faster than hot water yuk yuk yuk
