SC info needed
Don K. From Pa.
01-06-2003 17:13:08
I have an SC s/n 503279. Two questions: 1) What year is it? I've been told both 46 and 49. 2) It has the original Autolite generator the I rebuilt. It had an undetermined 3 wire regulator that no longer works. The only listed part is a cutout. How do the fld, gen(arm), and btry wires connect to the 2 terminal cutout? A new voltage regulator is pretty pricey and I'm trying to stay as close to original as possible. Thanks!
Roger A. NY
01-07-2003 07:00:42
 Re: SC info needed in reply to Don K. From Pa., 01-06-2003 17:13:08
Don K,
I count only six numbers in the sn. that you listed. There should be seven and what I often see is people miss the first number as sometimes it is just about under the left hand rivet. If this is the case and you can't read it, it is also stamped on the engine where it bolts to the transmission, leftside at about the 10 o'clock position and going down around the flange.
If the first two numbers you listed are right then it would be a 1946. Hope this helps! Roger
Gordon
01-06-2003 17:54:23
If you think the regaulater is costly buy a regaulater switch they are about the same.
