Leaky 430 injector pump
Illini Case
01-04-2003 18:55:09
My Case 430 has a 188D with a Bosch injector pump. The tractor starts and runs perfect but the injector pump leaks fuel badly out of what I would call the throttle shaft. Is there a way to install a new seal. I really don't want to rebuild the pump, I just want to stop the leaking diesel.
Tom
01-05-2003 09:36:29
 Re: Leaky 430 injector pump in reply to Illini Case, 01-04-2003 18:55:09
Take the numbers off the pump and take them to a local bosch inj pump dealer and they should have in stock a new shaft with seals on it. It's fairly easy to take out and put back in. I believe the shaft just has a small allen bolt on the side for the manual shut off. hope that helps.
scottAR
01-05-2003 19:31:09
 Re: Re: Leaky 430 injector pump in reply to Tom, 01-05-2003 09:36:29
Did all the 430s have Bosch pumps? I had a couple of 530s and they all had Roosa Master. I figured the 430s were the same.
Tom
01-06-2003 18:08:25
 Re: Re: Re: Leaky 430 injector pump in reply to scottAR, 01-05-2003 19:31:09
Sorry you are correct. I meant Roosta Master. The Bosch pumps came out on later machines. Sorry. But the info is still correct.
