Hello all.. I've been quiet for quite a while but I've been reading all the posts just like I've never left... anyway... time to make up for being quiet so long I guess... I remember when... I used to have to shovel the barn out and throw it on the ol' manure pile out back of the barn all winter long in 10 below temps in the Michigan Upper peninsula winters. Then when the snow melted in the spring/summer we would spread it over the pastures in hopes that a better crop of hay would spring up that summer. Then when that "better crop of hay" would spring up, I'd spend the long afternoons mowing hay... that IHC Super W-6 running like a raped ape and that International 990 haybine mowing down hayfields like it was cool... Raking hay with the IHC W-4 and baling with the New Holland squarer baler pulled by the Allice Chalmers WD-45.. Stacking hay wagons, putting up 1500 square bales averaging 70 lbs a piece, per day was an average days work for our hay baling crew. Until we got all 12,000 bales put in the barns for the year and we were considered finished with the hay season. Then it was on to the sawmill.. sawing timbers on dad's M-14 BellSaw with 40" saw spitting chunks of dust where logs used to be. The '39 CASE DC-4 running the mill then later replaced by the Super W-6 after the Case was deemed "tired" and needing a valve job, badly.. Dad parked that '39 DC-4 Case when it was needing work and I'm restoring it today... that and the 1940 DC-4 we've aquired along the way. That "46 Super W-6 is still pulling that 990 haybine around the Upper michigan hay fields as if it were many years ago. And that NH baler has been replaced by a MF 124, in Dad's operation, but my uncle is still using the NH, cranking out bales as if it were new. I'm here to tell you that the MF 124 cranks out bales like you wouldn't believe.. I got re-initiated to it after being gone for 8 years (military commitments and what not) and it was all I could do to keep up with it. Dad got a break this year and only had to drive tractor as I stacked wagons and tossed all the bales. Can I say I missed it... yes, and no... you can take the boy out of the country... buy you can't take the country out of the boy.. Dad, Glad I could help this year and I'll be home to help again this summer.. -Mark
