Help with a filter
Richard Davis
01-03-2003 20:51:22
I'm used to Allis' and Johns'. Bought my First Case its and early SC (Cann't Find serial number)
with single front wheel. I drained the oil and went to change the filter, couldn't find it. Bought a manual for 32.00 at TSC, doesn't even say any thing about the location of the filter. PLAESE help:
1.) Where is the oil filter located?
2.) How much oil in the sump? 5 quarts? Between the two plugs?
3.) Where is the serial number?
Mike Schotte
01-03-2003 21:51:57
 Re: Help with a filter in reply to Richard Davis, 01-03-2003 20:51:22
Hi Richard,
Congrats on getting the SC. Everybody was talking about the single front wheel SC that CASEPOWER had for sale last week. I've never seen one of these single wheel SCs in person. Post pics when you can.
I'll try to help you with your questions:
1) The oil filter is located in a bolt-on filter canister on the right hand side of the engine block directly above the starter. If it's an early model tractor, it may not have had a filter. (My '45 SC wasn't equipped with one.)
This is a crappy photo- but it will show you the filter location on an SC:
third party image
I can give you the filter element numbers if you need them. Just let me know.
2. Oil capacity: the crankcase capacity (including filter) is 6 quarts. The oil in the pan should be up to the level of the upper pan plug after the tractor has been run and oil has been pumped into the clutch housing. (which has a separate drain plug.)
3. The serial number is located in two places. One location is on the data plate on the dash. The other is on the flange of the engine block. See the link I've posted below for photo of engine serial number location.
Hope this helps.
-Schotte
Richard
01-04-2003 06:22:41
 Re: Re: Help with a filter in reply to Mike Schotte, 01-03-2003 21:51:57
Mike,
Thanks for the info. I didn't think Iwas blind on the filter cause they are either on the side like your pic or in the sump. Mine just doesn't have one at all must be earlier modle?. No number on the dash, link didn't work for engine s/n. A little more about the tractor, the brakes are not together like on the newer tractors, the left is on the left side, the right on the right side.
Thanks for the help
Richard
