Oliver man needs help with a case clutch
Nick Faessler
01-02-2003 18:59:41
I am helping a friend with a Case DC do a clutch job. We thought it was only stuck at first, but decided to spilt the tractor. The lining was piled up and we need need linings and rivits. The first question is where to find this or a rebuilt disk assembly. I already checked this website, T.H.E Company and North American Clutch and Driveline. The second question involves the pulley hub that the pulley mounts on. It's brake arm is supposed to stop the input shaft of the transmission when you push the clutch pedal in. The hub does not have a pulley because the loader frame would interfere with it. The hub has been ground off where the brake arm rubbed on it for the prevoius owner. Can I turn down the hub and press a sleeve on it or am I going to have to find a replacement hub. The serial number is 8031736.
Thank you in advance.
Nick
Gordon
01-03-2003 18:02:35
 Re: Oliver man needs help with a case clutch in reply to Nick Faessler, 01-02-2003 18:59:41
In the antique books Rusco advertise.I do not have his number now.
