Model D carb
Ken Tabor
01-02-2003 18:25:48
I have a Dmodel 1950 with a zenith carb. I put in a carb kit, which doesn't really come with much as far as replacement parts. The thing leaks fuel unless the shutoff is closed at the tank. I am suspecting something is wrong withthe float. Any suggestions or tricks. I still haven't got this thing running yet.
Ken
Ol Chief
01-03-2003 20:46:06
 Re: Model D carb in reply to Ken Tabor, 01-02-2003 18:25:48
With several folks having the same problem,sounds like the factory either did a sloppy job on the needle and seat machining or set the float incorrectly.You might try carefully lowering the float slightly which may wind up fully closing the valve,but only a slight change in angle of should float arm should do the job.
CASEPOWER
01-03-2003 10:19:53
Sounds crazy but I perfer to take a original needle valve and put it in my drill press and tke a file to it to polish it. You just have to make sure you get the angle right..
the hickdaddy
01-05-2003 10:40:13
 Re: Re: Model D carb in reply to CASEPOWER, 01-03-2003 10:19:53
i have been able to fix several flooding carbs by smoothing out the stair step on the needle which prevents it from seating correctly. replacement needles have neapreen on the tip and can not be smoothed out
Paul f
01-03-2003 08:41:58
Ken I just rebuilt mine also and agree about the paucity of replacement parts in the kit. Mine always leaked aroung the power needle valve (plus it would vibrate it self wide open periodically). The rebuild kit only included a fibre washer for the needle shaft. After reassembly it still felt loose. I took out the needle and found a small O ring that just fit over the threads. I put it on first then the fibre washer and reassembled. So far no leaks and the handle is harder to turn so hopefully it won't vibrate open...not run enough to test that yet.
Did you have any problem with the governor lever across the front of the engine rubbing against the generator belt at idle after the carb rebuild? It seems on mine that the new throttle shaft and arm with the kit may be positioned differently. My governor arm used to touch the belt but now it rubs hard and won't idle down all the way.
Paul f
01-03-2003 08:41:52
North M
01-03-2003 07:51:00
Rebuilt mine last year with a kit I got from Napa but seemed to miss the parts I really needed. End result was it leaked if allowed to stand with the shut off on. Runs fine otherwise so I make sure that I shut off the sediment bowl everytime I leave it.
