VAC 14 narrow front
James
01-01-2003 14:53:32
Ive seen lots of VAC 14s but not a narrow front one until yesterday. Is this something somone changed and put under it or did they make them and if so how rare is it. Thanks for any info
Mike
01-02-2003 14:53:34
 Re: VAC 14 narrow front in reply to James, 01-01-2003 14:53:32
I have a VAC 14 narrow front.The ser. num. tag reads VAC14 6003170. The grandson of the original owner says thats the way it came new.
ED CRANKCASE
01-02-2003 13:26:54
seen one in indiana, at the gyger ranch. tag reads vac14!
RoyG
01-01-2003 18:10:58
There were a few VAC 14s built and shiped with trycycle front ends. Most of them were ordered that way in rocrop parts of the country. Have not been able to find out haw many.
James
01-01-2003 16:15:55
 Re: Re: VAC 14 narrow front in reply to CASEPOWER, 01-01-2003 15:28:46
The problem that i see is the tag reads VAC14. I will get the rest of the # tomarow. Im posotive its a 14 because the lower seat the steering coloum is lower so imposotive its a 14. Thanks for helping.
Les...fortunate
01-01-2003 15:04:09
That would make it a VAC-12 wouldn't it?
hayseed
01-02-2003 19:02:47
 Re: Re: VAC 14 narrow front in reply to Les...fortunate, 01-01-2003 15:04:09
I think the problem is if you look in CASE buyer's guide it is misleading as they did make vac 14 with tricycle front ends . Just like the hood , grill and dash the front end on vac 13 and 14 will not fit vac. So the 13 and 14 had to came from the factory with tricycle front end thats what I think anyway .
Tim (Wheel-nut)
01-25-2003 15:42:51
 Re: Re: Re: VAC 14 narrow front in reply to hayseed, 01-02-2003 19:02:47
According to the books that Ive seen, The VAC-12 is with tricycle and the high profile platforms and seat. Which is the VAC that I have. Also equipped with 34" rear tires The VAC-13 is the same tractor with wide adj. front axle. The VAC-14 has the low profile platforms and seat. Most parts on the 12, 13,and 14 are interchangable
