DC engine misses and pops
Okla/Kans Bill
12-31-2002 18:00:15
I got a 48 DC engine in my grandads 34CC. The same thing is happening with it as happened with the CC engine. #4 is mising and the engines pops. I put a qt of Marvel Mystery Oil in it tonight . Maybe its to early to tell if that will help as I only ran it bout 1/2 hr afterwards, Iffn ya got any thoughts Id surre appricate them. I put a new spar plug in last nite, but no go. I pulled the valve cover but everything looks good there. Thanks beforehand
Lejo
01-01-2003 14:37:06
 Re: DC engine misses and pops in reply to Okla/Kans Bill, 12-31-2002 18:00:15
Had the same problem with my 641 ford. Found it to be the spark plug wires. Replaced all , problem solved. Remember some do not have copper wire running internally, it's a graphite center.
Lejo
01-01-2003 14:36:25
Jerry
01-01-2003 04:49:17
Make sure that every thing is ok under the valve cover. Look for a push rod that is stuck in a locked position. We have had this happen with several SC"S and also 800 and 400 tractors, Push rod may be bent and out of lifter holding valve open. Valve may be adjusted too loose and sometimes the push rod is getting totally under tappet.
CASEPOWER
12-31-2002 18:05:02
Check for spark first. If you have spark check the compression. Also make sure that the valves are not to tight. Are you using electric start on it? I would like to know if you cut out for the starter. I am getting ready to put a DC engine in a CC and was wondering.
Zach
12-31-2002 22:48:52
 Re: Re: DC engine misses and pops in reply to CASEPOWER, 12-31-2002 18:05:02
Is the Dist. Cap corroided?? and i would check points out and wires.
Okla/Kans Bill
12-31-2002 18:23:45
How can I tell if a valve is to tight? Ive got spark, but im going to get another spark plug wire, as possibly I am using the same wires offa thre CC I used on the DC. Worth a try. NoI wanted to use the starter, but I have had to change the ring gear, and that was too much for me. I had a plug made where I work to fit the hole, slipped a couple O rings over it ans shoved it in and clamp[ed it down with the starter lock nut. Sorry i coudnt help you. I am 56 years old and aint gonna be able to crank it and m,y 37 30 forever, and I was sure hoping to be able to use the starter. Oh well. Take care and thanks. Bill
Clint
01-01-2003 04:44:24
 Re: Re: Re: DC engine misses and pops in reply to Okla/Kans Bill, 12-31-2002 18:23:45
Bill Could be a valve is set too tight if it is only #4 cylinder that is popping or missing. Loosen off the set screw on the first two valves nearest the gas tank. Then reset to 18 thousands cold. You might also look to see if one of the two valves is stuck open. "not completely closing" As for putting on a starter I did one on a '34 C Case. Just by adding a starter Flywheel to the belt pulley and mounting a starter. Worked like a champ on the low compression C engine.
