Revisit 311 charging prob.
C.D. Zook
12-31-2002 14:17:05
6 volt positive ground system. All wiring contact areas cleaned thoroughly &wiring checked out. Rebuilt 6 volt generator and double checked for proper output, new 2 gage batt. cables,new regulator from case/ih and have tried 2 different new case/ih regulators, double checked for proper grounding in system. With tractor running 1/2 throttle,and I remove the neg. cable from batt. post, engine dies. voltage off gen. armature checks at less than 1 volt, run jumper wire from batt. terminal to gen. terminal on regulator and then volt check off gen. is 6 plus volts. ???? any suggestions will be appreciated.
AllanC
01-01-2003 21:33:39
 Re: Revisit 311 charging prob. in reply to C.D. Zook, 12-31-2002 14:17:05
It sounds like maybe you don't have connection from the regulator Batt terminal to the battery. Does this wire go to the switch? Check switch for continuity. The name says it all - That terminal has to be connected to the battery.
C.D. Zook
01-02-2003 05:14:36
 Re: Re: Revisit 311 charging prob. in reply to AllanC, 01-01-2003 21:33:39
Hi, Allan C. The batt. wire goes from the amp. gage to batt. terminal on reg. Could prob. be in amp. gage?? I will run a jumper wire direct from batt. to reg. batt. terminal & then check gen. outout. Thank You, C.D. Zook
AllanC
01-02-2003 20:41:27
 Re: Re: Re: Revisit 311 charging prob. in reply to C.D. Zook, 01-02-2003 05:14:36
Yes, it could be the Amp guage but more likely just the connections rusted or the wire broken in the insulation right by the terminal.
C.D. Zook
12-31-2002 14:25:20
I forgot to mention that I am also now using a 6 volt batterry, in place of the previous 8 volt battery, but charge prob. results are the same. The 6 volt does not turn engine as easily as the 8 volt did. Thank You, C.D. Zook
