Hey Casepower...Old Iron...Anybody...DC-4 Rocker Arms and Push rods I have 3 quick questions before reassembly!
Greg
12-30-2002 12:31:24
Greetings...
A premature "Best of the New Year" to one and all....
Took apart the rocker arm shafts on a 49 DC-4 because oil was gushing like a river out of holes on top of the rear two arms and next to none was coming out of the holes on the top of the arms on the front two...
Both shafts appear clear of debris but the holes were positioned differently for each shaft. The rear shaft holes were pointed up towards the valve cover, about 30 degrees off centre... toward the push rods.
The front seemed to be positioned downward on a slight angle toward the push rods. but not the forty-five degrees it suggests in the manual.
I am currently soaking them in gasoline and hope to reassemble in the next day or two.
Here are my questions:
1)Am I right to position the holes downward at a forty-five degree angle towards the push rods for both shafts?
2) EXACTLY HOW MUCH OIL SHOULD BE COMING OUT OF THE HOLES ON THE TOP OF THE ROCKER ARMS AS THE ENGINE RUNS?
3) After the arms were off, my buddy grabbed the push rods and started lifting them up and down about four inches each before I could stop him.... Will this cause a problem with lining them up with the lifters on the cam shaft?According to the manuals, it says the push rods are to be removed out the top when the head is being removed. It didn't say anything about it causing a problem with the lifters on the camshaft but I want to be sure....I DON'T LIKE SURPRISES...
Thanks
Greg
Larry
12-30-2002 16:54:57
 Re: Hey Casepower...Old Iron...Anybody...DC-4 Rocker Arms and Push rods I have 3 quick questions before reassembly! in reply to Greg, 12-30-2002 12:31:24
You are right about the position of the holes in the rocker arm shafts. There should be about 1 drop every 5 seconds coming out around the rocker arm shaft at each rocker. The push rods fall right back down on the tappets very easily and you shouldn't be in any trouble. Look in the Tractor Photos section and you will see my 49 DC.
Greg
12-30-2002 18:01:19
 Re: Re: Hey Casepower...Old Iron...Anybody...DC-4 Rocker Arms and Push rods I have 3 quick questions before reassembly! in reply to Larry, 12-30-2002 16:54:57
Thanks Larry
Your old guy sure looks good.
I'd like to get Gramp's old machine spiffed up...but single income, two small kids, long hours at work, etc....keeps me working at a snail's pace.
The paint is faded but there is little to no rust. She starts really well. I've redone the wiring, fixed the lights, fixed the radiator shutters, checked the connecting rods for clearance on the crank, cleaned all the filters, stopped the gasket leaks, and now have adjusted the rocker arm shafts. The clearances don't seem to be too bad. Besides, if it starts well, there shouldn't be too much wrong there.
I don't want to put the time into the body until I've got the wrist pin fixed..but I'm told I might as well take off the head, redo the rings and valves, hone all the cylinders, etc....and moneys a concern.
I'm thinking of joining the local antique tractors club. What I'd like to find is someone would would mentor me through the rebuild process...I've got the manuals, know where I can get the parts I need...I just would feel better with alittle more experience working beside me. You know, the voice of caution saying "Well you cold do that I suppose, but here is what will likely happen". Who knows, maybe I'll get lucky and someone will be interested in helping me out.
Thanks for your help. Best wishes in the new year.
Greg
Bob
12-30-2002 22:59:23
 Re: Re: Re: Hey Casepower...Old Iron...Anybody...DC-4 Rocker Arms and Push rods I have 3 quick questions before reassembly! in reply to Greg, 12-30-2002 18:01:19
Greg
Old Case tractors are easy to restore. They were designed to be maintained and even rebuilt by a farmer in the field using much lower tech equipment than we have nowdays.
The only problem now is availability (and cost) of spare parts
Other than that, with a manual to assist, you can confidently do almost any repair or maintenance work on them
It is especially good to keep a machine that has a family history, in running order.
