David Brown 990
Stephen R. Cebe
12-30-2002 07:41:37
Does any one have any information on the DB990? I don't know what year it is yet, but it has a loader and new hydraulic pump. The ad says it is a 65hp diesel, I have a book that says the 990 was 55hp(?). Other questions are, what to look for as far as problems. Are parts still easily available? Is this a good tractor? Any info on this would be great. Thank you in advance.
rhudson
12-30-2002 19:20:54
 Re: David Brown 990 in reply to Stephen R. Cebenko, 12-30-2002 07:41:37
good tractor, great on fuel, wish i could find another. Keep trans/hydraulic oil clean. don't let it run out of fuel (takes a lot of bleeding to get rid of air in fuel lines). get a manual from Elmer. the david browns are werd enough that you need a manual to know all the "tricks".
S.Cebenko
01-03-2003 10:16:23
 Re: Re: David Brown 990 in reply to rhudson, 12-30-2002 19:20:54
rhudson,
Thank you for the info.
Elmer
12-30-2002 14:50:44
First 990 was built in 1961. Look for damage at the front axle. Make sure clutch releases at the pto stage. They were a good tractor. I have all kinds of David brown parts and they are not hard to come by. I also have manuals available.
S. Cebenko
01-03-2003 10:14:54
 Re: Re: David Brown 990 in reply to Elmer, 12-30-2002 14:50:44
Elmer,
I see your name alot on this board. Thank you for responding.
Jens Andersen, Denmark
12-30-2002 10:56:11
When the first 990 came out around 1964 they were
56 engine hp and 51 pto hp. Then in 1973 or 1974
they ratings were increased to 58 engine hp. Up
until 1967 they were red and having a 6+2 trans-
mission and were called "Implematic" which were
the name for the 3-point. Then until 1972 they were dark brown on the chasis, and had a 12+4 transmission and "Selectamatic"-3 point which
were a lot better.Then the rest until 1980 they
were orange and white due to the Case acquirement.
Hope this helps. Jens Andersen
S. Cebenko
01-03-2003 10:13:03
 Re: Re: David Brown 990 in reply to Jens Andersen, Denmark, 12-30-2002 10:56:11
Jens,
Thank you for the info. He doesn't exactly know what year it is, so this will be useful.
