Vickers Hydr. pump
Marty
12-29-2002 19:30:58
I pick up a Vickers Vane Hydr. pump the # on it is V 210 1A 12 it has a 3/4" shaft and one 1" port one 3/4" port can any one tell how many Gal.an Hr. this pump is , and any other Inf. on it I want to use it on a loader tractor Thank you Marty
George G.......Update
12-31-2002 06:03:26
 Re: Vickers Hydr. pump in reply to Marty, 12-29-2002 19:30:58
After posting first reply. I came across a service/parts book on the V21 pump. It show's two pumps that were not on the spec sheet. one being a 8 gpm pump, the complete number would read V120-8-1A-12. The other being a 11 gpm pump, the complete number would read V120-11-1A-12. both pumps would be right hand turn as you are looking toward the shaft end. Maybe someone else can give you a little more insight on this pump.
George G
12-30-2002 10:48:18
Number should be V210-*-1A-12-S214-LH. The missing number would be gallions-per-minute. The pump is a auxiliary pump. It mounts onto a PVA 150 gpm variable displacement pump,and is used for control/pilot pressure. It is left hand rotation as you are facing the shaft. You will need to change the rotation. To calculate the gpm, All you need to do is, Measure width of rotor;this is W. Measure shortest distance across bore ( I.D.of cam ring); this is D. Measure longest distance across bore ( I.D. of cam ring); this is L. Formulae is 94xWx(L / D) / 4 x (L-D) / 2 = gpm at 1800 rpm. The / stands for divide by.
mj
12-30-2002 06:09:37
Go to the link and fill out the e-gram.
