Stuck motor
Greg
12-29-2002 13:55:32
I just purchased a very straight and clean Case 500B. But the engine is stuck. What would anyone suggest in trying to break motor free. It's going to sit for awhile. I would like to use some kind of solvent or something to put on top of pistons. Anybody have any ideas?
Flambeau red
12-31-2002 19:35:42
 Re: Stuck motor in reply to Greg, 12-29-2002 13:55:32
In my stuck SC, I used Marvel Mystery oil and WD 40 and I let it soak for over a year. Every so often I would try to turn the engine with the hand crank or rock one of the rear tires back and forth. I eventually took the head off and tapped down on each of the pistons with a block of wood. A friend of mine and myself, rocked one of the rear wheels back and forth vigorously and we got it to break free finally. Fortunately, the sleeves stayed in place. I chose this method because there was a lot less risk in forcing the pistons and causing damage to the sleeves, valves, and to the head. You just have to use your own judgement as to how long the tractor has been stuck, evaluate the risks for each action that you are taking.
Tom Bush
12-30-2002 13:37:53
Mike Schotte wrote an article on how to do that.I believe he's had success with it.You can read the articles I think it was titled "Stuck SC" or something like that.Anyway,his e-mail is on most all his comments.I'm surprised he hasn't come to your resque already,but I may have kept him, answering some of my questions. Good Luck, Tom Bush
C. Amick
12-30-2002 10:05:27
Don't remove the head. If you try to free up the pistons without the head on the engine you will just shove out the sleeves. Don't try to turn the motor over without making sure the valves are free or at least loosen the adjustment so you won't bend the push rods. Read the articles on freeing stuck engines on this web site. That's my 2 cents worth.
Ralph
12-29-2002 14:38:41
Marvel Mystery Oil and patience
INCase
12-30-2002 07:31:06
 Re: Re: Stuck motor in reply to Ralph, 12-29-2002 14:38:41
There are alot of items in this web site on this subject. Use the search feature. I myself haven't had much luck with straight auto-trans fluid... not much time to mess with it either though... haven't even pulled the heads yet to see whats going on... good luck
Wes Schmidt
01-20-2003 04:25:10
 Re: Re: Re: Stuck motor in reply to INCase, 12-30-2002 07:31:06
Try Gibbs penetrating oil. You can order it at Gibbasize.com. They have had a lot of success with stuck engines.
DC4
01-01-2003 10:31:50
i have had excellent luck with transformer oil if you can sweet talk the local electric co-op out of a gallon or two. if you cant, coca cola always seems to work wonders. thats what i use anyway. hope this helps and good luck at your project.
