Update on case LA rebuild. More questions??
Texas Red
12-29-2002 13:34:15
OK i have the crank and cam back in the engine, Now it is time to figure out which pistons to use. I sliped in one of the propane pistons and it is 1/4" below the deck. put one of the gas pistons in and it is 1/8" above the deck. I am having the propane head reworked and new rings. Now my question , what is the compression ratio on the propane pistons i have and the propane head?? I read where the propane pistons were even with the deck?? OR would it be better to mill the high altatude gas down to be flush with deck??
What would the compression ratio be then?? I need some advice frome someone that has put one of together before. Thanks for the help TR
Bill Hires
12-30-2002 07:25:15
 Re: Update on case LA rebuild. More questions?? in reply to Texas Red, 12-29-2002 13:34:15
The "LA" engine is 404 cubic inch displacement, or 101 cubic inches per cylinder. The gasolene engine compression ratio is 4.83-1. This gives a combustion chamber volume of 20.91 cubic inches. I can't find the LP gas compression ratio, later LP engines varied from 7.46-1 to 8.5-1. I will use 7.5-1 as a compression ratio, giving a combustion chamber volume of 13.46 cubic inches. Every 1/8 inch or 0.125" removed from the top of the piston would increase the combustion chamber volume by 2.1 cubic inches. This would give a compression ratio of 6.49-1, removing 0.250" from the top of the piston would add 4.2 cubic inches to the combustion chamber volume, giving a compression ratio of 5.71-1.
