Somebody help me!!
JeffsCase
12-28-2002 21:21:22
Here's what I'm wanting to do. I have a gas Case 830 engine which is 284 cid with 4 1/4 inch pistons. I want to bore the block to accept the sleeves from a Case 336 engine which has a 4 5/8 inch bore. Then I want to bore the sleeves another 1/8 inch to accept 4 3/4 inch pistons. This will give me 354 cid. My question is: What trouble am I going to have finding a head gasket. Do the 284 and 336 have the same head bolt patterns. If anyone has the spec's, please email me.
Jim M
12-29-2002 04:11:26
 Re: Somebody help me!! in reply to JeffsCase, 12-28-2002 21:21:22
You can get head gaskets custom made, there are adds in Antique Power. Why don't you just bore the block for J/D 5020 sleeves that have the 4 3/4 bore if there is room. Let us all know if this works I have a 251 propane motor I would like to do that to for a 400.
Tractor or Dragster?
12-28-2002 22:29:10
If you are going to bore the sleeves another 1/8", no one in all of Christiandom will be able to help you. Seriously. That's way too much metal to remove. Confer with a good machine shop as to how much allowable overbore you can get with out turning the sleeves to rigotoni.
JeffsCase
12-29-2002 13:49:09
 Re: Re: Somebody help me!! in reply to Tractor or Dragster?, 12-28-2002 22:29:10
Boring the sleeve 1/8 inch would only require taking 1/16 inch off the wall. Do you think that would be too much?
Oldfarmboy Jim
12-29-2002 20:18:55
 Re: Re: Re: Somebody help me!! in reply to JeffsCase, 12-29-2002 13:49:09
WAAAAA AAAAAYYYYY YY TOO much!!!!! ! There are excellent reasons why there are limits to how much you can shave off of sleeves, crankshafts, brake rotors, etc. They all have to do with how much stress, pressure, tension, heat absorbtion (and any other mechanical or thermal forces) the article was DESIGNED to take. I doubt any reputable machine shop would even consider boring a sleeve 1/8" over. Remember, what oversize pistons you can get for a rebuild??? They're measured in THOUSANDTHS of an inch, .020"
.030". A 1/8" overbore would be one hundred twenty five thousandths .125" You don't have to be a master machinist to know how fast that engine will disintegrate. Jim
todd
12-29-2002 13:02:14
My God man, what are you trying to do??? When boring, you are talking about thousanths of an inch, not 1/4's of an inch! I have found that whenever you start tinkering with what the factory originally did, you can get yourself into some nasty little problems. It seems like one leads to another, and so on. If its more power you want sell the tractor and buy another one.
