DC valve clearance
smotch
12-28-2002 19:33:14
I need the valve clearance specs. for my 1952 DC.I thank you in advance.
a.kselvamani
01-13-2004 06:52:00
 Re: DC valve clearance in reply to smotch, 12-28-2002 19:33:14
details of dc valve with diagram
Mike Schotte
12-28-2002 22:17:48
According to my Case Model "D" Series Operator's Manual (Sixth Edition):
"Clearance should be .018 inch when the valve is fully closed and the engine cold."
"To simplify this adjustment, a gauge .018 inch thick is furnished with each tractor. This guage is located on one of the long studs which passes through the rocker arm shaft bracket."
Hope this helps, -Schotte
