Did the SC ever use different hand cranks?
Mike Schotte
12-28-2002 11:25:33
Hi All,
I asked this question to Don L. awhile back, but didn't have the photos to make clear what exactly I was talking about:
The hand crank hole on the '45SC parts tractor is different than the hole on my '49SC tractors... the '45 has "notches" on each side of the hole to accept a crank with pins.
I've tried the crank from the '49 in the older tractor, and it appears to work just fine.
The spring-loaded "coupling" that engages the crankshaft pulley has the engaging pins on it... so my question is: Was there ever an earlier design for the SC where the hand crank engaged the engine directly? The block on the '45 has been replaced, so I suppose it's possible that it could have been upgraded at that time.
Here are some pictures of what I'm talking about-
The round hand crank hole on the '49SC:
third party image
The slotted hand crank hole on the '45SC:
third party image
Thanks in advance for any info. Hope y'all had a great Christmas.
-Schotte
Don H
12-28-2002 16:00:10
 Re: Did the SC ever use different hand cranks? in reply to Mike Schotte, 12-28-2002 11:25:33
Mike, The slotted hole is a new one on me. I've got a 2 -41's, 44, 2-49's and a 51. They all have round holes.
Mike Schotte
12-28-2002 16:42:47
 Re: Re: Did the SC ever use different hand cranks? in reply to Don H, 12-28-2002 16:00:10
That's very interesting to know, Don H.
This is the first time I've ever run across the slotted hole, too...
It appears to be made like that from the factory. The build sheet for this unit wasn't available from CASE because it was one of the war year tractors.
There's a '43SC in a local museum, but it has the round hole, too.
My parts manual doesn't show any differences to the front crank assembly.
I wonder what other interesting things I'll find while working on this tractor?
It's definitely a mystery. Maybe Don L. can solve it for us.
-Schotte
Elliott
12-28-2002 14:55:37
I have 2 -1947 SC Cases and they have the round hole like your 1949. What have you got on the 1949 12 Volt Reg.?
