Case VAO
Ted in Sacramen
12-24-2002 14:56:22
12 or 6? I imagine this tractor started as a 6 volt, positive ground. Feel free to hammer me if I'm wrong. Currently has a resistor? in series with the coil and distrbutor, is there a cross reference for Auto-Lite, which is the starter, no marks on the generator, which would tell me if this unit was running 6 or 12.
Slowpoke
12-24-2002 23:20:42
 Re: Case VAO in reply to Ted in Sacramento, 12-24-2002 14:56:22
Try starting with 12v battery. When(if) engine starts, remove ground cable. Engine should keep running. Check with voltmeter for 6 -8 or 12-13.8 volts
Or remove generator to the bench, and run it with a 1750 rpm motor. Use a slightly smaller pulley on the motor than the gen...see what you get.
Caution: Repairing tractors can be dangerous and can result in injury, death, and/or propety damage. Use care, useing this advice is at your own risk.
(Do we really need to include this statement?)
Captn.n/e,Mo.
12-25-2002 05:47:20
 Re: Re: Case VAO in reply to Slowpoke, 12-24-2002 23:20:42
your disclaimer forgot :
(may be hazardous to your wallet)
Ted in Sacramento
12-25-2002 00:58:17
Thanks for the tip, now all I have to do is get it started and that should be just a carbuetor away. Looks like Santa couldn't find one or I've been bad cause there's none in my stocking.
