DB 996 brake repair/oil seal replacement
James
12-23-2002 17:57:36
I am replacing the right brake pads on my 996. I've held the differential lock down, and removed the final drive assembly. My brakes are covered with oil or hy-tran. I'm not sure which.
Elmer, I've seen you suggest whenever the final drive is removed to replace the two oil seals. I'm assuming by 'two oil seals' that you mean the two axle case seals.
Should I go so far as to replace either of the other two sets of oil seals in the final drive unit? (One just outside the brake drum and one just inside the final driveshaft?) These two seem like a job for my dealer if you feel they could be the cause of my wet brakes.
Thanks, James
Elmer
12-24-2002 04:11:34
 Re: DB 996 brake repair/oil seal replacement in reply to James, 12-23-2002 17:57:36
Yeah you better change the seal behind the drum too. It has to be pulled. You may want to bring it to a dealer to have it changed. The drum has to be heated up to fit it back on. Check the vent bolt. It is the top 3/8 bolt on the cover of the final drive. A 9/16 wrench fits it. Make sure it is not plugged. If your brake shoes are not wore out you can put it in your barbque and bake the oil out. DO NOT DO THIS WHEN YOUR WIFE IS HOME!!!I got caught by my wife and what a tougue lashing i got. But then 22 years of marriage results in selective hearing. There is an Oring under the sleeve on the axle shaft behind the drum too. Check the actuator shaft to see if it is free enough. Then is the time to remove it and clean it up. They can sieze up too.
