Rebuild on CASE LA
Texas Red
12-22-2002 09:54:04
It is almost time to start puting the LA back together. I have located the index marks on the cam and crank, Is there a mark on the mag-gov gear also or is there another way to time the mag?? This is also a propane block and head we are rebuilding. we are going to put the crank, sleeves and pistons out of the gas engine that was froze and busted into the propane block. It will be put on gas so does the time have to be changed any??also the propane pistons are in good shape, what would be the best combo to go back with?? We are going to put the propane Cam and lifters back in it. We have a lot of good parts to pick from. Thanks for any and all help. TR
RobertTX
12-22-2002 20:43:31
 Re: rebuild on CASE LA in reply to Texas Red, 12-22-2002 09:54:04
I am afraid Ralph NH has been too kind, I am not that sharp on mixing the propane parts. The best thing to do is to set down with the parts book and sort out the numbers. I have looked at heads and pistons numbers, but not camshafts. I don't think there are different cams, but I may be wrong. The parts book can be a little confusing and intimidating on these parts because Case does not show succeeding and replacing parts in order in the book. But if you make your own notes and work through the list, usually you can figure it out. One thing I have learned is that when Case made a parts number change, the new part may not be a direct replacement for the changed one. Often other parts were changed and it is necessary to replace the assembly, so it is best to check fit of all parts before final assembly. Also, might want to post on the pulling board, some of those guys are parts swapping wizards and have some special tricks.
Texas Red
12-23-2002 02:41:39
 Re: Re: rebuild on CASE LA in reply to RobertTX, 12-22-2002 20:43:31
We set one of gas pistons and rod up next to one of the propane pistons and the gas is 1/2" longer. It looks like the piston pin is lower on the propane piston. When we get the crank back in i guess we will have try to figure which combo wil work best. Thank for the reply . TR
Ralph NH
12-22-2002 10:12:09
Red, I have a service manual for the LA that says to get a spark from the #1 plug wire by holding it next to the mag housing, but make sure the mag doesn't turn any farther than the spark position. Then get the #1 piston at TDC with the mark "D" on the flywheel by looking through the hole by the starter. Carefully install the mag in that position and you should be okay.As far as propane versus gas parts, Robert TX could probably help. I'm just a novice at this but I still love those LA's. I have 4 LA engines. Good luck
Allanc
12-22-2002 13:10:20
 Re: Re: rebuild on CASE LA in reply to Ralph NH, 12-22-2002 10:12:09
You can time the mag by loosening the nut on the drive, just before the mag coupling. I dont recall whether theres a mark on the gov gear or not. Not really necessary.
Texas Red
12-23-2002 16:57:12
 Re: Re: Re: rebuild on CASE LA in reply to Allanc, 12-22-2002 13:10:20
Thanks for all the help, The gaskets will be here soon and then all the fun starts. Rebuilding these old tractors is almost as much fun as s@#
