Loader on 4490
peter in mn
12-21-2002 12:38:31
Has anyone ever put a loader on a 4490 or 2470, 2670? It seems as if it would work but will it ?I'm looking for answers. Thanks
Max
12-21-2002 15:24:29
 Re: loader on 4490 in reply to peter in mn, 12-21-2002 12:38:31
It would work but you would need the construction quality one, not an ag version. Also it would be very hard on the power shift ech time you push in the clutch (inching) pedal for all of the motions that the trans goes through. That's just my opinion, I prefer a torque convertor in front of the trans for loader work.
Lloyd
12-21-2002 18:21:44
 Re: Re: loader on 4490 in reply to Max, 12-21-2002 15:24:29
Yes, I have seen a loader on 3 or 4 24/2670's they used them in silage bunker silos. the power shift trans works real well with a loader be cause you do not grind any gears between forward and raverse. The ones I saw all had Artsway loaders, I do'nt think they make them anymore.
Max
12-22-2002 06:20:11
 Re: Re: Re: loader on 4490 in reply to Lloyd, 12-21-2002 18:21:44
I've seen them too in silage pits, my only problem is when you push in the clutch, the power shift goes into reverse mode for smooth shifting but most importantly I like the torque convertor setup like on a 580D backhoe where you can hit the pile and not worry about the clutch.
